- Joined
- Jan 16, 2003
- Threads
- 345
- Messages
- 3,650
- Location
- Charleston
- Website
- www.oldenorthstatecruisers.com
Alright guys some of you had seen the tank mounted under the truck at a few of the HAMOM's over the past couple months but in an effort to make trail repairs easy at Harlan I worked through getting everythink installed. Luckily we never had to use it really in Harlan. We gave it a shot as we were getting ready to leave-had to change out Barry's tires and one of Jared's for a safe drive home.
Overall I am very impressed with the setup, used one of the last few brackets greatlakes had made and though there were a few small qwirks in getting it mounted it was nothing to stop me from buying another on if they were available. Nice laser cut piece with very clean welds, but with anything when you are only making a select few of a unit and welding it yourself things tend to "shrink/warp" slightly. Nothing a quick dremmel touch couldn't solve. Other nice feature about this setup is that it uses a toyota pulley so replacement is made easy. In the pictures you will also see the new 3 groove pulley that was machined for the belt.
As for the rest of the unit well after searching through online suppliers for indivdual parts I decided on taking an alternate route, kilby sells nice stuff but in my mind it was a bit higher in price than I thought the entire setup could be put together. So I ventured out to Sears and a few other big box stores to see what they had. I found a 3 gallon unit that seemed like it would work perfect and it was on sale, so I walked out the store under $80 for everything (mostly) under the price of Kilby's 2.5 gallon tank. This saved a great deal, and as you will see already had me setup with a Atuo on/off Pressure switch, Pressure regulator, Pressure Guage, Tank, air intake side air filter, 4 quick disconnects, tire chuck and guage coiled hose, and a few misc. pieces to setup other small accesories. Only parts I had to source beyond these was the 3/8" air line, check valve and coecselating filter seperator.
I was fortunate enough to have been given a brand new never installed York 210R unit with a brand ne clutch which also saved me the hassle of junk yard searching for the unit and rebuilding or what not. I was hesitant in installing the unit as it was actually a factory 1976 FJ55 A/C compressor that would have been dealer installed but I thought I would never use it otherwise and this was ideal, hell it's the reason I bought the last bracket in the first place.
So overall the install went pretty smooth, only issue was that over thinking I checked everything 3 times I didn't realize I had installed the check valve backwards which caused a small issue when the 300 PSI hose blew up-lets just say these yorks pump a good bit of air in a small amount of time. Once that was removed and installed correctly the unit was tested for functionality, on at 90 PSI off at 125 PSI. Tank fills in about 14 seconds at 1,600 RPMS. Ran the impact on it in Harlan and other than a low torque impact it seemed to drive it just fine. Air all 6 tires up yesterday evening in a little under 10 minutes.
Heres a few pics for reference, if anyone decides to make a go at this let me know and I will gladly provide the part numbers/parts I used.
