I have searched and read until blue in the face.
Here's my story. Started having a vibration that seemed to be in the driveline. Checked the u-joints and the rear one was bad. Initially part of the vibration was better, but not ever gone. Now it's getting worse. I have re-changed the u-joints with NO effect. I have checked both the TC flange and the differential flange by hand and they both feel tight with no wiggle up and down or side to side and no in-out. I took out the rear driveshaft and drove around in FWD. The vibration was GONE when I did that, so I know it's somewhere in the rear driveline. It seems to be worse above 60 or so and especially with minimal to no load. Strong acceleration or deceleration lessens it. I jacked it up and the cranked it up to about 70. The driveshaft looked super smooth. The only vibration I could see was the passenger side rear tire, but I have to think it's not just a tire since the vibe was gone when I had the rear driveshaft out.
Could it be a bad bearing in the axle? How about the pinion? Can you feel it by hand if it's gone bad? Can the driveshaft look smooth yet still be the culprit? Help!!!!!!
