I disagree that there was no thought put into them. They just lived in a world that didn't require going over 45. The primary reasons they are so scary is the steering setup, and they have the exact same steering as the Willys and the FJ40 had early on. It's a nightmare.
So, here's what I'm thinking right now. fire fighting skid is 800 lbs empty and 2500 full. Something like this.
An affordable, quality skid - slip on unit is what makes our FIRELITE® FDHP-306-200 series slip on unit a popular choice for budget minded fire departments.
www.kimtekresearch.com
So, current thinking is
Still thinking of staying leaf spring front and rear. Just not sure if the existing springs or mounting locations will work, or if the axles will force me to go outboard a little.
Dana 60 out of super duty front and rear - with air bags in the rear to help when the firefighting insert is in place. ARB lockers with onboard air to work the bags.
5.7 with sniper for absolute simplicity - probably a crate engine. Enough people are familiar with the sniper now that I think it's a better option that OEM ECM because you have some visibility and adjustability in the engine with the little 3.5" display. All new fuel system and sniper high pressure in tank pump.
Manual transmission (not sure which one yet). But, even a 4 speed would work.
Atlas 4 speed with 8:1 final ratio. that should be low enough to move around with full tank on the back.
And I'm leaning towards just going full hydro on the steering. It would need assist anyway, so, just go all the way.
All new brake setup to work the brakes on the Dana 60's. The brake pedal on the M37 goes down (it does not hang), so assuming it stays that way I'll need a frame mounted booster or a remote booster. I'm not real familiar with that world, so I'm learning. We could also convert to a hanging pedal assembly - it can't be that hard to shove something like a Jeep or FJ40 thing in - which might actually be easier in the end - for both brakes and clutch.
And, I REALLY want to keep the winch, so I have to figure out a way to run it - absent the PTO. But, the power steering pump just isn't big enough. Two power steering pumps? A separate large pump - can't be 12v.
