LukeZero
Deeply Confused
So, on the back of Bugly- I have a Spicer 1350 series CV joint, about 8" of slip splines, then a Tom Woods goofy off-set U-joint. Since I pulled the Cruiser case and installed the Minitruck case- I was measuring for driveshaft modifications and I find that the shaft won't extend or collapse. So I'm figuring its 'hydraulically bound-up' because it's pumped full of grease. I pull the zerk fitting. Still won't collapse. Put all my weight on it- won't move. Put it in the shop press- 2000 lbs pressure- won't move. Strap one end to the base of the engine hoist to see if I can extend it- won't move. It's either hellaciously rusted- or the splines have been twisted and are now bound together.
I guess my next stop is Action Machine to see how much it'll cost for them to cut out the splines, re-use the CV end and the yoke end and make me a new shaft. (It needed to be shortened anyway- so I guess here's my chance).
Any ideas what the fu*k is going on with this driveshaft?
Luke
Luke
