Wanted WTB: Power Antenna Assembly with Wire to Radio
Discussion in 'Classifieds - Parts' started by ncsudrewh, Feb 11, 2009.
  1. ncsudrewh
    ncsudrewh
    68
    2
    Jan 18, 2007
    Greenville, SC
    I need a FZJ80 power antenna assembly with the attached wire that connects to the radio through the dash. I really only need the tube that goes around the expanding antenna which also has the antenna wire bonded to the side (as my antenna wire is damaged). It is OK if the motor does not work or the usual mast is broken. See circled area in image below. Thanks!
