- Location
- United States
I need a FZJ80 power antenna assembly with the attached wire that connects to the radio through the dash. I really only need the tube that goes around the expanding antenna which also has the antenna wire bonded to the side (as my antenna wire is damaged). It is OK if the motor does not work or the usual mast is broken. See circled area in image below. Thanks!
