Now if he's willing to pull it or sell it IDK![]()
To be fair I did prepare you, it was the only one I knew ofTexican has one Pig with PS and the reply was along the lines of "you ain't getting it."
Tucker
Have you tried contacting Meryl at Classic Cruisers?
Pm me your number and let's talk, you just might motivate me
Delancy,
I just remembered. The '79 factory setup requires a different steering shaft, as well. THAT's going to be hard to find.
If it boils down to it, I can modify the OE shaft to fit, since it's a shortening, not lengthening process.
Can refab the shaft....can't refab the gearbox. Haha.
I believe it was on PBB, but cruiserbrett depicted the process, and it wasn't extreme, if memory serves.
I noticed you said "holding fast" Hope this is of interest to you or someone.
I noticed a '77 Chevy Monte Carlo with a straight 6 like the Pig (any older GM straight 6 would do), and I snagged the PS pump and mounting bracket. (I noticed later this bracket was readily available at CCOT) a bit more pricey, but ready to go.
I called Lance at Iron Pig (He has a post on the tech page of this forum) , and they had a custom mounting bracket for the gear box which included an integrated shock mount.
