Wanted WTB:2H Power steering pressure lines
Title says it. If anyone has the high pressure hose that go from the PS box to the pump, and the return hose to the reservoir, I'd love to buy those. Please PM me or answer here.
HJ60 85 and up.
thank you,
Jan
Hello,
If you have the original hose go to a local hose shop, they can put your ends on new hose for cheap!
Hola
eric
I don't have the original hose. Here's the problem: My 84 HJ60 has the old style pump. It is leaking and not rebuildable, since the parts are not available anymore. So I bought a pump from a newer 2H, which also requires swapping the engine mount, BTW. However, the newer pump styles have the entry for the high pressure line on the top, not the side, so my old line would get bent sharply, which I want to avoid. Hence, I need a new line.
thank you, cheers,
Jan
I would still check with the hose shop, my local shop makes all kinds of wierd and unusual hoses. They even had BST fittings for my oiling system for the turbo. Don't underestimate them, and prices tend to be very reasonable, gonna be cheaper than JDM.
eric
