what are the symptoms of your issue?
They’re listed in Toyota’s parts catalog as to be ’02 - ’07 Land cruiser or LX 470. So, I’m guessing it likely won’t, but IDK for 100%. Thanks though!I have a 2001 LX470 master switch and door harness if that would help. Not sure if the switch is the same.
I probably should find one in the 02-07 range, to be safe. Thanks!
Yeah, looking at the window lock switch, seems like the newer model is flush at the bottom.They’re listed in Toyota’s parts catalog as to be ’02 - ’07 Land cruiser or LX 470. So, I’m guessing it likely won’t, but IDK for 100%. Thanks though!
Anything in a thread abut this, you know of? Maybe some more detailed info, pics? I traced things the best I knew how. The ground wire the Po installed was spliced into the harness wires and then bolted to the door. I removed it and it made no difference one way or the other. Strange.Check the ground at the window switch. In my 2006 lx the ground wire inside the door harness boot was broken nd caused all sorte of gremlins. Sounds like the po tried to solve that but the door hinges prevent good grounding probably
Check for continuity between the white with black stripe wire at the connector and the vehicle battery. Should be very little resistance
what it sounds like to me is that ground the po added was possibly not adequate.Anything in a thread abut this, you know of? Maybe some more detailed info, pics? I traced things the best I knew how. The ground wire the Po installed was spliced into the harness wires and then bolted to the door. I removed it and it made no difference one way or the other. Strange.
Ok, well I’ll redo it and ck continuity, through all wires and see what I get. The only thing the aftermarket did was to make the lights go out when closing the doors, which helped but works like a cheap POS, IMHO.what it sounds like to me is that ground the po added was possibly not adequate.
