I originally posted this as a question, but since I've figured it out, I'm editing it with instructions.
Problem:
I wanted to load a new marsflex TPMS Sensor ID into my 2013 GX460 ECU (before installing the TPMS transmitter into the tire).
I had trouble figuring this out because all the 'programming' options in the xtool TP150 are for programming sensors, not the ECU.
Solution for 2013 GX460 (pretty simple):
Problem:
- Find Bad Sensors
- xtool TP150 -> TPMS -> Asia -> Lexus -> GX Series -> 2003.08-2017.08 (315 MHz) -> Check
- Measure each tire pressure by clicking the wireless button and waiting at least 1 minute, holding the xtool next to the stem.
- Wait at least 1 minute for each tire.
- Tires with dying batteries may take around 1 minute to update.
- This identifies sensors that need to be replaced.
- Add Replacement Sensor to ECU before installing in Tire
- Measure each 'good' tire's pressure at the stem.
- For bad tires, move away from the car and measure each replacement sensor's pressure (to record its Sensor ID in the xtool TP150)
- At the end of this, the xtool will have the Sensor ID's of everything you want to write to the ECU
- Connect xtool to ODB port with cable. Energize car.
- xtool TP150 -> TPMS -> Asia -> Lexus -> GX Series -> 2003.08-2017.08 (315 MHz) -> Relearn
- This writes everything you ust measured with the xtool (including the new sensor ID's) to the ECU.
- Check that it worked (by reading from the ECU)
- xtool TP150 -> TPMS -> Asia -> Lexus -> GX Series -> 2003.08-2017.08 (315 MHz) -> Diagnostics
