WP + TB replacement, while I'm in there parts?
procuring the below parts, anything else I should get?
1. Water pump
2. WP gasket
3. Fan pulley
4. Thermostat
5. Water outlet gasket
6. T-stat gasket
7. Timing belt
8. TB Tensioner spring
9. TB Tensioner bearing
Water pump will come with gasket if you are going OEM.
I would add the following:
Upper radiator hose
Lower radiator hose
Radiator cap
3 belt set (if you have AC)
Gasket for the timing belt cover
Timing cover oil seals (x2)
90* positive crankcase vent hose
Fuel filter
just to update (@NanaMaru) My good friend has my parts on order and will hopefully get here before the end of February. Its really good to have friends all over.
Yes indeed ..... :)
Hello All
Thanks for the info on this thread. My t-belt light has come on at 180,000 kms so I am gathering the parts to replace the timing belt, water pump and other ancillary parts but I have a couple of questions.
Is it really suggested to replace the fan pulley? Does it fail?
Can someone point me to the timing belt tensioner bearing. I can't seem to find it on the EPC.
Thanks!
Peter
Hello All
Thanks!
Peter
1HZ? what year?
There is an idler assembly (bearing) and a tensioner spring you need. You can get the whole timing belt replacement kit that comes with everything you need including water pump from Cruiseroutfitters.com ( @cruiseroutfit ). Or Order all the OEM parts you need through @beno
The part numbers can be found under "camshaft & valve" category in the EPC
We (Cruiser Outfitters) would love to help, we stock Japanese Toyota and aftermarket timing belt kits for the early/late HZJ (and thus PZJ) as well as the belts, hoses, thermostats and gaskets for the 1HZ and 1PZ (though we may not have every 1PZ hose, I'd need to check when back at the shop)
Hello All
Thanks!
Peter
@peterb ove had nothing but experiences with Cruiser Outfitters. Just my $.02
Thank you all for your replies. I have also had good results using @beno and @cruiseroutfit to source parts. Since no one responded to my question concerning the fan pulley, I'll presume it does not need to be replaced.
Peter
I'd do it while you're in there. Doesn't hurt. I try to put in new parts as I go. I would have done the full wp and such with my radiator but time was a big factor.
