Are any of these marked? I'm not sure how to identify quality (or not) leaf springs
Sometimes you can see the makers names on top, usually stenciled on in paint. Again on top, they are usually stamped L or R , A or B.
If the springs were added in Japan, they have some quality gear.
Your springs have the desirable double military wrap on the ends, which was onc a sign of quality but some of the rubbish are using these now.
Actually after a closer look , I think you have junk on the front and quality on the rear. The junk are the non tapered thickness leaves with square cut ends and the unclosed brackets holding them together.
I'm still not 100% sure on the part numbers for the shackles
The factory bushes are rubber, most of the aftermarkets are nylon based. I think there are only eye 2 sizes on the 7* What is the year of yours.
Good to know. Driver's side on RHD or LHD?
On Toyotas RH and LH sides is determined by sitting in the vehicle looking forward. Its the best way to express it because there is a combo of L and RH drive vehicle owners here.
What does it ride like on bad roads?
