...of course, I had to fail as a gross polluter in CA to qualify...and it's "while funds are available", and it's only for up to $500 after the first $100, and it's only at a handful of certified stations. (What a mouthful!)
So, my 60 failed smog with high CO, and higher at speed. From reading here, air injection is what people suspect in this case). I don't remember seeing it, but I'm going to check to see if my choke is stuck--seems like that would cause it too.
The lemonade from these lemons is that I may be eligible for $500 of emissions-related work, the catch being that it's at a certified shop of which there are only a handful (and of course, none I've heard of).
The big question is, *is* a H55F an emissions-related expense? I mean, it will change my emissions readings at a given speed, you know? Ok, maybe not. But, what would *you* do? Perhaps get a a cheap catalytic converter? I have no need to pay them to change my plugs or some such, but is there expensive parts/labor I could get cheap out of this deal?
Oh, and of course any emissions hints are gladly welcome.
The numbers:
15 mph:
RPM: 1645
%CO2 meas.: 13.1
%O2 meas: 0.0
HC PPM meas.:50 (Max 189, GP 370)
CO% meas.: 2.61 (Max 1.33, GP 2.83)
NO PPM meas.: 39 (Max 1448. GP 2669)
25 mph:
RPM: 1645 [what's with this--everyone else is higher!]
%CO2 meas.: 12.8
%O2 meas: 0.0
HC PPM meas.: 44 (Max 113, GP 288)
CO% meas.: 3.08 (Max 1.13, GP 2.63)
NO PPM meas.: 29 (Max 1308. GP 2469)
The numbers:
15 mph:
RPM: 1645
%CO2 meas.: 13.1
%O2 meas: 0.0
25 mph:
%CO2 meas.: 12.8
%O2 meas: 0.0
