I've got an incredibly odd and very frustrating problem that I've been dealing with for weeks, and any help or advice would be greatly appreciated. I had the truck(a '98 100 series with 150k miles - pretty much stock) towed to Toyota twice in the last four weeks because of a starting issue like many others here have had:
https://forum.ih8mud.com/100-series-cruisers/341011-cruiser-cranks-wont-start.html
https://forum.ih8mud.com/100-series-cruisers/179908-help-im-irate-ignition-trouble.html
https://forum.ih8mud.com/100-series-cruisers/402506-1999-uzj100-intermittently-drops-dead.html
Before the two towing sessions I replaced the fuel pump, all fuses related to ecu's, efi, etc. (although all tested fine) and double checked all relay and ecu connections but nothing made a difference. The immobilizer light would not go off when I inserted my key, the car would crank hard, but not start.
After the second tow to the dealership I talked with a tech about possible problem areas and I pointed out that when I bought the truck there was a very slight sunroof leak on the passenger side which I promptly fixed (it has been bone dry inside ever since). They visually inspected several of the connection points in the dash close to where they thought any moisture buildup might have occurred, and found that there was some corrosion on the connector that ties to the ABS computer. They told me the ABS system overrides the immobilizer as well as several other computer related starting systems and said that one of the wiring harness connectors should be replaced. They replaced the connector and told me it was ready to go and that I could pick it up anytime after paying the $350 charge.
I show up after hours to pick it up and it dies twice on the way out of the parking lot with almost every dash warning light flickering on and off the whole time. I leave it there that night and they call me two days later and tell me it's impossible to track down the "bad spot" in the wiring harness and the only way to solve the problem is to spend an additional $1650 to replace the entire front/main engine wiring harness (Toyota said they know it's a harness issue because there are no codes thrown each time they go to check).
I'm not sure what to do...money is definitely an issue. Should I buy a used harness and cut half of it and solder it to the half of the harness (passenger side dash) they suspect is bad? Do I just go ahead and replace the whole harness? Again, any help or advice would be greatly appreciated. Thanks for your time and help.
