i just got a great deal on a big sandblast cabinet. my shop compressor will not be able to keep up with it but i have another portable compressor with a similar pump, and i think that both in series could keep up. i have tried them hooked together and it does work pretty well, but the problem is controlling them both in synch because the pressure switches do not trigger at the same time, so the one that requires lower psi to trip does not go off unless you deliberately drain air and fight the other compressor.
has anyone tried wiring two compressors together like this? my idea would be to install a single large main air storage tank with inputs at opposite ends that would receive air from the stand alone compressors after they fill their own tanks. that tank would then feed a single output to the sandblast cabinet (or anything else)
the trick is how to trigger both compressors to go on automatically at the same time. i want to somehow use a single pressure switch to trigger both so that i don't have to worry about the pressure switches going out of synch. in a perfect world i would also like to have one motor delay triggering for 10 seconds after the pressure switch flips to reduce the momentary load on my garage circuit (they are on separate circuits on a 60 amp subpanel circuit).
any suggestions?
any suggestions?
two pump fix plus a lot of storage. my neighbour has some large old propane tanks i can use for additional air storage.
