Wiring fog lights to work with headlights? (1 Viewer)
I have 2 6" LED light bars wired so when I hit my brights they come on. They're in the pockets for running lights in my ARB and are just wired straight to the hi beam wires. Works well.
How would the wiring work? Now the fogs have three wires running from the fogs.
I had 2 wires from each LED bar. + went to + and - went to -.
I wired 2 led cubes cut into my bumper as DRL lights. I wired them to the marker lights by tagging the power line from the markers and then grounding. They don't draw enough power to matter on the marker circuit. When marker lights are on, or headlights for that matter, white cubes are on.... but can turn off if I don't want them by just turning the headlamp switch all the way off.
It is pretty easy to do this without buying a new harness. Use a relay that has once source of power constant from the battery. The signal power comes from the headlight circuit. The normally open relay will hold power until activated by the lights coming on and then will send power to the fogs. Easy day.
