Wiring Aux Driving Lights to High Beams
East Bay, CA
Website
www.jeffreyswansonphotography.com
Has anyone wired their aux lights to come on automatically with the high beams?
I searched and it turned up some folks using the stock fog light wiring for aux lights and then how to "fix" that so they still worked with high beams, but I'm interested in something different.
I just want the lights to come on and off automatically with my high beams. I don't trust myself to be fast enough with dimming my highs and switching off the aux lights for folks coming the other way.
My previous vehicle was a 2011 Subaru Forester and I was able to wire the aux lights in that fashion by finding the right wire from the headlight plug. I haven't checked out the wiring diagrams to see if I could do it in a similar fashion on the LC. The Subaru also had lowered voltage high beam DRLs so it should be possible on the LC.
Yep, that's how it should be wired up in Australia.
You can only switch on the driving lights when high beam is on.
It is very easy as you only have to find the activation wire to your high beam and feed that to the relay.
Always use a relay!
Inputs are: battery, switch (you don't need the driving lights all the time), high beam activition.
Outputs: earth, driving lights.
