Wiper motor issues (2 Viewers)
monniepoo
Cruiser chick
Website
www.monniepoo.com
Anyone have their windshield wiper motor go out? Or is it even a motor? Seems mine had a mind of their own this weekend and then got stuck in the up position. I pushed them down now they won't work. Any suggestions?
Hi Monnie. Possibly a fuse or a lose wire on the wiper motor. Not sure where the fuses are located for the wipers. Not sure on motor either. Might also be the relay which is located in the switch on the steering column.
Did some looking around and the motor is on the driver's side up near the cowl area and the fuse is located inside the fuse box in the driver's side. It's a 30 amp fuse and looks to be the only one there. Found this looking at the electrical PDF on the brockandbecca.com site page 25 for the fuse box and page 39 #A11 for the motor location. I checked on the blue room and could only find one thread similar to your problem and it was the guy's relay in the column switch.
I wonder if this would have anything to do with having my ARB lights installed :hmm:
It might. Maybe blew the fuse or knocked a wire loose or something. If they tied into the wiper circuit it may have overloaded it.
I need to fix this. Maybe someone will know what I should try. The middle wiper is the only one that will not work. I don't think it's a power issue. I will research online to see. I need to fix this before tomorrow. Heading up the hill and I'm sure it's going to be raining.
You need a "trouble light" or voltmeter that will allow you to trace the 12v to the motor. If you have voltage to the motor and it doen't turn, likely the motor. If you don't have 12v there, it could be the switch or a wiring fault between...
I got it working. Went to auto zone to get a new blade for the middle. He put it on and now it won't work. It has to do with the screw and the arm. I don't know anything about it but I'm winging it. I'm wondering if maybe there is a washer or something I'm missing. Too tight won't work, too loose it's not catching. Hmmm?
maybe this has something to do with the whole 3 wiper thing. :hmm::lol:
Its fixed. The right tool can get the job done! Ha"
Use the right socket (doh) and tighten but not too tight. Make sure they are lined up correctly. Had to do that a few times. My problem was it was not seated right. Now I know that it makes a clicking sound when it's pushed all the way in. I think I was trying not to break it.
Sent from my touch thingy
I see this is an old post, but a friend of mine brought over his 96 TLC with the windshield washers NOT working and stuck in the upright position. He had taken it to the Toyota Dealer and they said the motor was bad and there were no motors available. He ordered an aftermarket assembly and I pulled the old Toyo assembly off and installed the new aftermarket unit. After blowing several fuses, I disconnected the new on and dug into the old one. I pulled the top of the motor and found the two magnets and delaminated. I cleaned everything up and glued the magnets back into their original location (easy to see) and lubed it up and put it back together. Works fine except on high! Will check with the owner to see if it worked on high before? Will check the relays anyway. Simple fix
