windshield replacement questions
cruiserdan
SupportingVendor Emeritus
Moderator
Enlarging the cabin garage
I'm out of the office til Wednesday so I can't give you a specific number. The windshield is not bad and the weatherstrip is actually cheap. DO be sure that they glue it in as mentioned above. I happen to have a PPG windshield in mine because I wanted a top-shade, something not available OEM.
I had to replace the seal last spring, $26 from Dan, and reused the jobber glass installed by the PO. Had a local do the install, he knew what he was doing, knew to run a bead around the inside of the seal, and so far no leaks.
