windows won't work
North Cadillac
I checked the fuses inside the truck and in the engine bay. None of my windows will roll down or up. One is down now and i just hope it doesn't rain.
Any ideas?
Any ideas?[/QUOT
Did you check the window lock button
have you tried the other switches or just the master switch?
check the 10A gauge and the 30A FL power fuses in the cab
check the big 50A AM1 fuse under the hood
check the fusible links on the battery
if you have a meter check the fuses for continuity, sometimes a blown fuse does not look blown.
Thanks for the response. I have checked the window lock and that's not it. I did not pull the big fuses because i don't have a meter.
EDIT: Thanks Raven, it was the 30 amp. Tha'ts the only fuse i didn't pull to check. I will replace and see what happens.
Thanks again guys.
