Window weather stripping source? (1 Viewer)
Do you mean the c-shaped rubber that surrounds the window and goes in the door frame and down into the window guides inside the door?
That's part number 6814189105 looks to be unavailable from Toyota. If you have a piece of the original, take it to a shop that caters to auto body shops. They should have a supply of different types of rubber channel that should work. I know you can't directly duplicate the 90 degree corner of the door frame, but it can be glued together.
I think this is it? I guess I just pop the panel off and press it into the channel.
It's the non-wing window that you can't get.
Yes that’s the correct part # 6814189108 I just replaced my driver side.
I just pulled out the old one and worked the new one in the channel. The front short side was the hardest to get in I sprayed a little silicone on the back and it went in finally.
Yea, both the corners are cut out of mine. I get a nice whistle at highway speed. But the fox will be down a while while I do the timing chain. I’ll probably redo the exhaust while I’m at it and helicoil the exhaust manifold. I’m gonna replace a lot of hoses and such as well. It’s in such great shape, I just wanna bump it up s notch. Then maybe trade her off for a decent 60 series to work on. That has always been my final destination. But the 22RE is so cool it will be hard to let it go.
