Window Rocket - who’s tried it? (10 Viewers)
Looks like I am good to go then as I don't have the springs on the pedal correct? From googling it seems the pedal assist is mounted to the clutch pedal arm hence the interference.
That looks very similar to the pedal I have. To be safe, if you measure horizontally from the top edge of the ABS computer to the nearest part of the clutch pedal you will need 1-3/4" minimum. The Window Rocket will be 1-5/8" from the ABS computer surface.
I tried installing the window rocket with the included 12mm standoffs positioned to offset both the ABS computer and the window rocket away from the clutch pedal, but there is a trunk of the wiring harness back there that says nope to the ABS computer moving any further back from where it is.
Window Rockets are in stock. This Window Rocket fits LHD and RHD 80 series made with ABS brakes. Final assembly has been streamlined. Trimmed some labor here and there. Lowered some of the parts costs with higher volumes.
The new price is $265
Probably still too much for some of you cheapskates.:flipoff2:
Later this month (2-3 weeks from now) there will be Window rockets for FJ80's and RHD 80 series without ABS. The mounts are prototyped. Some revisions will be made and production will start in about a week.
Thanks for all the support!
Still showing 375.00 on the website. Is there a discount code or something I am missing?
