The rear passenger Looks like the window reg. is going has anyone done this job themselves? If so do you have any pointers?
No, it sucks, but it's common I think. My '99 does it on the rear PS. I took the interior panel off once and sprayed some Toyota lubricant (It may have been silicone) and that helped for a while. I think it's got more to do with electrical current than lubricant. It seems that that motor may be the longest run for the power to the motor and it doesn't get enough juice.subspd said:Isn't it strange to have this problem on a 99'? I'll try the soap and water.
I would spray the soap inside the two vertical window guide channels...strange, but my rear windows are slow to roll up...even on warm days. Maybe there is a design issue/variance with the rear window glass/regulator.mainecruiser said:I have the exact same problem on the passsenger side rear window. Where exactly would you recommend spraying the soapy water mixture? Inside, outside, both? Just along the edges of the window or along the entire length. Thanks.
richg said:I have used silicone lubricant spray with great success on slow windows. The lubricating effect lasts for years as well. Just spray the guide channels down as best you can and roll the window up and down several times. When I picked up my 98 LC, the windows all went up/down at different speeds. Sprayed them down and all is good.
rich
