Winch Rope 7/16" Black Pure Dyneema SK78 Winch Line w Protective Sleeve Gusset Thimble,Hook
Placerville Ca
Has anyone used this winch rope from JM Rigging?
Specs-
PrevNext
7/16" SK78 Pure Black Dyneema Winch Line w/ Protective Sleeve, Gusset Tube Thimble and Pivot Hook.
Protective Sleeve Color Options: Red, Blue, Black, yellow, Orange, Green.
Gusset Tube Thimble: Heavy Duty Black Powder Coated Gusset Tube thimble, Made In the USA.
Pivot Hook: Grade 80 Alloy Pivot Hook with Latch
Drum Connection: L1 Lug Assembly
Available Rope With Sleeve Lengths: 80ft w/ 10ft Sleeve, 90ft w/ 12ft Sleeve, or 100ft w/ 15ft Sleeve.
Breaking Strength: 23,650 LBS
Made in the USA, and hand spliced in house.
7/16" Black Pure Dyneema SK78 Winch Line w Protective Sleeve Gusset Thimble,Hook​
SKU: WL-716-BLK-BLK-80
$356.00Price
Rope Color: Black
Pivot Winch Hook Color: red
PLEASE PICK A COLOR: Protective Sleeve Color: black
Rope Length
Quantity
  • Our 7/16" winch lines are made from pure Dyneema SK78 fiber manufactured by DSM in the Netherlands and then stranded into our high quailty rope here in the USA. All of our winch lines are built and hand spliced using a double locking splice here in Cedar City, Utah. Being we manufacture our own lines in house, we control the quailty of each winch line manufactured to ensure a top quailty product. Our winch lines are a great replacement for the traditional steel wire rope winch lines that come standard on most of today's winches. We use only a very heavy pattern black guesst tube thimble made in the USA on all of our winch lines. Our protective sleeve material is made in USA using mil-spec material. Even though our sleeves are tight to the rope they still slide up or down the rope so they can be used or positioned in hazardous areas. Our winch lines come standard with a bolt through style lug for easy connection to your drum unless a different style connection is required, if this is the case please just let us know when you place your order as the cost will remain the same. High quality American made Synthetic winch lines are the way to go. They are much stronger and lighter than traditional steel lines and safer to use. No more wire splinters or broken strands to cut your hands on. Easy to free spool and easier to wind in. Our winch lines can be cleaned with warm water and set out to dry.
    Our winch lines are easy to clean. DO NOT USE ANY WASHING DETERGENT/SOAP
    - Sit out to dry. Or simply hose off with garden hose. WE DO NOT
    RECOMMEND CLEANING USING A PRESSURE WASHER
    DO NOT USE ON SHARP CORNERS OR ON ANY PART OF THE VEHICLE THAT HAS SHARP CORNERS OR BURRS AS PRODUCT DAMAGE MAY OCCUR.
I'm looking for a reasonably priced winch rope with the strength to pull an 80 series in tough spots.
The comeup winch on my 100 series has black dyneema, it bleeds onto your hands a little. But your choice in winch rope will meet your needs.
The sk78 rope is the og amsteel. There should be no issues with this product. The price is fair. amsteel is running roughly 2.25/ft
