Winch repair?
hello I recently aquired a winch from a friend who couldn't get it working. He had put a new solenoid on it and it would just click. So I take it and pull it to pieces all looks alright except the motor was all rusted. I decreased it all and sanded back all the contacts and cleaned it out and put it back together now it would only spool out. I tried to connect jumper leads to the winch directly and couldn't get it working no matter what way I tried.
Should I just pull it all down again and give it all another clean out?
Thanks
Would be helpful to know what winch it is. Warn? Smitty? ect
If the motor only has two posts at the cap end it is a permanent magnet motor and connecting jumper cables to a battery should make it turn if everything is working. If the motor has three posts and a ground lug it is series wound and you need one more jumper to make it work. Connect + battery to F1, then F2 to A, then Ground back to - battery. Or more simply, connect regular jumper cables to F1 and ground, then another jumper between F1 and F2 (or use a sacrificial screwdriver!)
