Tigerstripe40
After getting stuck in some mud last weekend, I have decided to get a winch.
I Want a Warn winch, but since I have 2 rigs and limited funds, I want to use a multi-mount winch. I've pretty much decided on the Warn Zeon 10,000 though would consider the Warn 9000 XDi.
I'd like to have both a front and rear power receptacle on the trucks, but do have concerns about keeping the contacts from shorting out and potentially burning my truck to the ground.
It looks like the amp drap on the winches I am considering is about 500-600 amps when doing a full weight pull (not that I expect to do that much of a pull, just want the overhead).
I'd like to put the sockets onto a solenoid with a switch in the cab so I can turn them on and off (turn the front on, or the rear) as necessary. I'd also like to set up my jumper cables on the same connector (Anderson power pole connecter IIRC). Any recommendations there?
Though, that said, for the cost of the Zeon 10,000 w/ multi mount, I can get 3 Warn VR8000's...
Any thoughts?
Any thoughts?
