Will these tundra oem rims fit the lc 100
They fit. OEM Tundra wheels from 2007 onward with a 5 lug pattern.
The tire size depends on lifted or not. I run 275/70 R 18 Good Year Duratracs. I have a 1.5 inch lift. The tire is about 33.4" inches tall. They will probably work without a lift as well as 285/75 R 16 fits without a lift and they are about 33 as well. All the tires meaure out just a little different.
Sorry for the hijack, but think it is relevant to the OP original question.
Anyone know if you spare tire rim is built to the same spec as the 4 normal rims? Would it be safe to run 4 spare tire rims as your normal rims?
Look on the back of the wheel for the DOT rating. The one on the 80 series wheels reads DOT-T, so truck rated. John
