Im installing all new urethane shackle bushings. While I have everything apart I want to install new shackles too. They will be homemade, using the ConFerrs on my 40 for a pattern. They will be approx. 2" longer than stock, so roughly 1" of lift.
Id like to have everything I need gathered for the job since the truck is my DD. 1) Do you think I'll need degree shims for that much lift? 2) If I do shim, will I need longer center pins? 3) Should I replace U-bolts if I do shims?
Thanks, Hodag
Thanks, Hodag
