Hey Guys,
I'm experiencing a wierd problem when trying to start the 100. I think it has something to do with the security system, but I'm not sure. When I insert the key into the ignition, normally it starts great. But lately, on occasion, when I put the key in, absolutely nothing happens. I don't mean like starter problems or battery problems, I mean like nothing electrical comes on at all. No dash lights, no dome lights, no radio, nothing. It's like nothing on the vehicle that is electronic works at all.
This morning for instance, it started fine in the driveway, but when I tried to start up after I dropped my son off at daycare, nothing happened. I inserted the key and absolutely nothing works. Then I take out the key and re-insert into ignition, still nothing. The third time I did this, it started right up, everything electronic worked fine like there was no problem.
It's like something is shutting down everything electrical. I read in the owner's manual that the security system (vehicle immobilization system) reads the transponder in the key to start the vehicle. I started thinking that this may be the issue, but the more I think about it the more I'm not sure. When everything's dead, you can't work the power locks from outside the vehicle and when you open the door the overhead lights don't come on.
To make this even worse, twice now in two days, while I'm driving, everything electrical shuts off for about 5 seconds including the AC and the Nav system. The 100 drives fine mechanically when this happens. It doesn't affect the engine in any way, the brakes work fine. It drives fine, but it scares the hell out of me both times because everything turns off inside.
Any ideas on what this might be?
