Looking for ideas as to why my passenger side low beam won't light up.
Back story: I plugged in some 35w HID ballasts and bulbs to the low beam and it worked fine. Didn't work on one of the fog lights though.
I wanted more light so I got some cheap 55w ballasts and bulbs. I plugged in the PS bulb and ballast and used electrical grease on the connectors and around the bulbs o ring to create a good water tight seal.
I turned on the truck then flipped on the headlights. It fired up then stopped. I unplugged the OEM cable from the ballast and flipped it over to see if that'd work. I think I saw a spark from where that ground cable on the fender bolts.
Now the regular halogen bulb won't work. I tried different bulbs and different fuses in the underhood relay fuse box. Is there another fuse somewhere? Any Ideas?
I'm going to switch to the retrofit sources kit once I fix this.
I
I
