Why so much camber on 200?
Yeah far too much camber and not enough caster on the passenger's side.
Did the lift come with adjustable UCAs? In particular if they are SPC UCAs the shop may have turned the cams are far as they will go but if the ball joint on the UCA is set incorrectly they won't be able to get you in spec.
Thanks for all the info! I kept the original UCA’s as I heard that since it’s a pretty small lift aftermarket UCA’s shouldn’t be needed. So you think main things to ask for is to fix the caster and camber on the passenger side?
Correct.
