For the exact same reason my wifes lx470 did the radiator split at the top seam... After my engine install i was down to putting the radiator in and fire'n her up... but being an old dirt racer I wanted to clean the radiator before I reinstalled it... I use the same foaming coil clean&bright I use on A/C coils... amazing how much dirt & bugs wash out of the fins....
anyway I run the hose through the hose connections just to do a quick flush and damn if water doesn't pour out of the top seam... exact same as what caused me to put an engine in my LX470... it was a non factory replacement radiator... but i still had the oem one from the lx470 and that is where it also failed... I once had the same issue on a ford diesel (7.3) and it stopped when I went to a lower pressure radiator cap...
the good news is that this cruiser would still be on the road rack'n up miles if it wasn't for this failure... the bad is the fact that it was blown up is the only reason I got it...
with a catastrophic radiator failure you all but never see the temp go up because there is no coolant around the sending unit to make it register... on race cars we use to install a pressure gage in the coolant loop with a warning light to monitor coolant system pressure for this exact reason....
p
p
