Why Do We Regear Cars, Trucks, Jeeps, & SUV's? Watch the video as we explain some of the mystery & give you an inside look at the theory behind why this modification is so important if your vehicle is sporting aftermarket equipment.
*** Be Sure To Like & Subscribe! ***
The most important parts of your vehicle are the parts you never see. Most newer vehicles have a high-geared overdrive and are shipped from the factory ‘under-geared’ so that the vehicle runs at lower RPMs on the freeway. That way, the manufacturer can increase their overall mile-per-gallon average. Even slightly larger tires change the RPM at which your vehicle was designed to shift gears, creating more heat, wearing out your transmission and drive train pre-maturely. This, and adding heavy accessories, also puts more strain on your engine and transmission, greatly reducing your power and fuel economy. By changing the gearing, and effectively the gear ratio, you can easily take back all that power, fuel economy and reduce wear, adding years to your vehicle.
#NitroOrNothing #Overlanding #OffroadLife #Toyota #Jeep #GMC #Ford #Chevy #Dodge #Ram #AllTacomasNeedGears #4x4#RockCrawler #DailyDriver #DieselDrags #ProMod #X275 #RadialVSWorld #Nitrous
