it just started happening a couple days ago. i went to start my truck (1990 HDJ81) and the glow plug light only stayed on for a split second the truck was already warmed up so it started easily. yesterday -13 deg c in the morning and the light only stayed on for the split second again and it was hard to start and idled rough. again the same thing this morning. i looked mud here without much luck. the glow plugs are a super glow system, as it has the coolant temp sensor. cold starting seemed to get progressivly worse over the last winter compared to last. i tried to measure voltage at the glow plugs, my volt meter (fluke) only flashed some numbers for a split second but not long enough for me to make them out which leads me to believe the relay is working. it seems that the power isnt staying there long enough for it to do anything. so is it a shorted glow plug which fried the fuseable link that goes back to the timer? or is it the timer itself? or just burnt out glow plugs, or am i totally out to lunch? any inslight would be appreciated. thanks.
