Who sells Radiator overflow tank caps
Boise, Idaho
My overflow tank cap is worn out. I need to replace it and maybe the tank.
Does anyone know who sells these?
I tried the dealer, cruiser outfitters, cruiser corp, and ccot, and city racer plus eBay.
Thx
...caveat being, "Can also substitute for the discontinued FJ60 cap and hose, 16405-90A03. However, the hose to the radiator cap will be short by a few inches. Either replace with a longer hose or re-use the original one."
Thanks!
I searched their site yesterday and could not find it.
Maybe I need a new computer.
Thx
hi ,
i never dare speculate on anything that is OEM and also affixes to your Land Cruiser 's
1967 FJ40 - Dune Beige (L31/H55/SOA)
1969 FJ55 - Fashion Green/White (LM7/4L60E)
1985 FJ60 - White (LM7/4L60E)
so , lets have Phun with the 3 rigs in your signature line because you did not mention which of your 3-pack needs a tank cap because all 3 of yours are worn out , and BORATE deposits all inside because the PO used OEM Walmart GREEN antifreeze for the last 2 decades , and you like to go at your fleet overflow 's if 1 needs to be replaced maybe all 3 the tanks might like to all the Same Sparky NEW OEM Genuine NipponDenso Japan spec. parts .....
after all the OLD-SKOOL car show Judges at the 2025 Boise fair grounds Spring , Summer , and Fall mega Classic Car Shows score low for Yellow UV ray damaged Tanks especially when there
PLANT A-11 assembly line installed Caution Plate No. 2 's and the Modern Age TSB Toyota issued for the now 180' degree view so you " NEVER TOUCH WHEN HOT ", .....
i really like OEM overflow tanks , but i really like alot more attaching every single Dam possible OEM Decal i reproduce so there Factory Fit and Function details that matter status keeps you from touching when hot ...
