yes definately an electronic diesel fire . could be due to ulsd i have seen electronic and mechanical pump seals shrink, and spit fuel on the underside on the top of the bonnet sp;lashing on the turbo and then the flame starts. the other day I seen a 2004 pete come in idling in front of the shop, i smelled fuel (raw) I said shut it down popped open the bonnet and the head and valve cover was sweating diesel fuel , the electronic engines do not have exposed injectors they are in the head, well a few minutes later if on highway running full load there would have been a fire( not good) unless you work in a shop people really dont understand the prob. with ulsd on pre emmission engines- 2006
aaron
your seeing a lot of leakage? I literally cannot tell a difference in my 77 mercedes diesel. No leaks or anything. Still smokes once and awhile on hill...
not a lot of people in the diesel section complaining of leaks either.
for your prado, ever consider removing the electronic part of the diesel control? retrofit on some 2l-t pumps........
I was talking to a guy that is a fuel distrbutor and he said that the refineries add bio for lub. but it is not enough, he said that some refineries still make sulpher grade due to the demand but its a hastle hauling it because when he hauls for a ULSD customer he has to rinse the tanks out.So I assume that to prevent this from occuring you would use a fuel conditioner? My father runs some mid 80's era Macks and I would hate to see them burn up like the KW.
Also it was my impression that due to the low lub. qualities of ULSD, the refinerys were adding a lubricant so as not to wear out fuel system components. Would that not curtail the seal shrinkage?
Where are you getting B40 from? Did you find a hidden source in Abbotsford?![]()
I asked him how the computer could tell him when to shift if the truck was not even on the computer database, so had no knowlege of the engine or gearing.The idiot who "drove" my truck had to stop the test twice. He was either lugging the hell out of it or over reving it. When the test was finished, I asked him if he knew how to drive a standard. He told me he was just following the shift point the computer display had given him.I asked him how the computer could tell him when to shift if the truck was not even on the computer database, so had no knowlege of the engine or gearing.
Duh, he didn't have an answer for that one. I will be contacting AirCare and my MLA. BTW, it passed with flying colours.
John
