I want to power my toshiba satelite A105 laptop in my truck. Will any of the 75 watt or 150 watt inverters that plug in cig. lighter work. Would this be a problem if I was running the ac while running down the road in my 88 fj62
kkt said:I emailed targus who makes a ac/dc converter and got the message. My toshiba is too new for them to have an adapter. No Woody I would not be checking my email so you dont have to go off road.
Is an ac/dc adapter a better way to go than a power inverter?
Here is what I received from targus.
Thank you for contacting Targus Customer Support.
We are sorry but at this time we do not have a tip or an adapter to support your Toshiba Satelite A-105 notebook.
The tips are custom designed and tested on the supported computer models. In addition to the size and voltage requirements, the power supply logic board on the computer also impacts how the adapter functions with your notebook.
We consider your investment in your notebook and the data stored there to be much more important than the sale of an Adapter, so we cannot recommend a tip for your device.
For the latest compatibility information, please check our configurator:
http://www.targus.com/us/configurator/targus/default.asp
mabrodis said:Actually what you have now is an ac/dc adapter (you plug it into AC and it outputs DC for your computer). What you would want if looking for a cig-lighter type one a DC->DC converter, takes in DC and outputs DC (possibly a different voltage level than came in, via either a boost or buck converter setup)..or if your laptop will be happy with 12v directly, then you could plug it directly into the cig-lighter, you'd just need a cord, or sacrifice the one you have a make your own...![]()
All depends on which laptop, my laptop uses this:97 FZJ80 said:It's hard for me to see a laptop drawing more than 90 watts as that is the highest power adaptor/supply sold by Targus.
Bob_Garrett said:As an FYI, many of the toshibas can be powered using dc from the cigarette lighter. Supposed to be 15v, but seems to work ok as long as the vehicle is running.
mabrodis said:All depends on which laptop, my laptop uses this:
http://laptoptravel.com/Adapter.aspx?ID=2321&t=3
(I use the Dell one but that's a replacement, puts out 130 watts, for a Dell Inspiron XPS Gen2)...
97 FZJ80 said:WowHow big is the battery and what is the run time on that beast? Not passing judgments on why/how but doesn't that kill the portability factor of a laptop?
That's very odd IMO, I have had no problems using devices like chargers and such with a cheap (i.e. modified sine wave) inverter, typically the devices charge slower because the effective current is lower, since most use a diode setup which only grabs current when the voltage is high and since a modified sine wave is basically a square-wave it's only at a high-enough voltage for the diode to conduct for a short amount of time. I have seen where things like a soldering iron plugged into a inverter didn't get as hot as it should have...RavenTai said:I also found out I could not charge my dewalt batteries from this inverter as chargers need true sine wave,
Bodean said:Burned up 2 Dewalt chargers trying to charge with my 400 watt inverter. What's up with that. Expensive screw up!
Later,
