Which locker should i give my LJ78
A few pics in chotts, the KDj120 has stopped trying before it get too bad (the year before we got 4 cars sunk into the mud over the bumpers in a similar thing). I could drive around him, and pull him out without breaking the crust thanks to the torsen.
On an other pics i could back up gently while the crust was giving under my KZJ, my friends on HDJ80 and KDJ got stucked even know they are experience drivers there too. Torsens make the difference big time in this condition's:clap:
Syche I would love to hear your recipe. Say on!
Chad
Sent from my iPhone using IH8MUDp
Hi.
First you got to use the right springs for your application, we have been testing a few and ironman were by the worst on the kzj. I ended up with a mix of Eibach +40mm real, medium up front and kingspring medium +70mm at the rear which are actually a good +5cm no more. For long expedition, over a month in Mauritania with a lot of fuel, water, tools for the team and standard traveling stuff i added a 30mm home poly spacer on top of the rear spring to level the toy, great setup either empty and loaded. Eibach medium rear were way too low and soft.
I use slightly modified bilstein shocks(euro specs) up front which are the normally matched for rear landrover defender. The valving was perfect and they have a very long shock travel while keeping the same compressed length as the original toyotqa shocks. 2 mods to be done, the top fixing point, you need a bushing and 2 small spacers for the adaptation, at the bottom , just enlarge slightly the stud hole in the axle tab. You will have a 12mm lower rods which is a great improvement over the factory toyota 10mm one. Driving arround unloaded remove the front sway bar, it handles much better and offroad you will flex great even with light load on the axle (nose uphill situation for example). when heavily loaded on long trip i was putting it back on since the extra weight made the bar flex better.
For the rear, i used Koni shocks, serie 84, also for land rover and range rover rear. they use to be designed in the 80's for the landrover/rangerover used on the dakar. They were great, not too hard, long travel and not loosing efficiency, when heating up while being beaten in desert tracks. They don't exist anymore, i got one of the last sets available, but the serie 82 is very similar and should do about as good. Dont take the serie 90, they are way too hard.
I tested factory landrover shocks in the back (full hydrau), they were great around and on slow tracks, but after 1h african track they were way too soft due to the temperature, when cooled down they were back to normal. If you only do low speed tracks, no problem. The only mods needed are a 20mm spacer at the rear top bump stop and re drill of the axle tab for the 12mm rod.
I also tested euro specs bilstein for land/range rover rear( same as i had on the front axle), but they were too soft on tracks and not good enough in rebound on slow offroad, going up rocky steps for example.
Tested OME L series for lj/kzj, good for local offroad, totally useless for expedition loaded and their 10mm lower rod is just looking to let you down on a small jump or on a big twist. (had one to go on a twist and others leaked after 30mn african tracks, replaced under warranty and handed to a friend who use his kzj locally only). the OME L serie (long travel) were a touch shorter than the landrover shocks.
OME springs, not installed on mine but on the rig of friend were doing almost as good as my mix.
landrover defender / rangerover, rear shocks will increase your wheel travel by a bit more than 100mm front and rear, this is a huge improvement. You can't really do anything better without completely modifying the suspension geometry and going 3 or 5 longitudinal links.
I was using the same tire size as you but on BFG km1, 265 75r16, great size for a kzj used everywhere.
So depending where you are and what you do, get yourself a set of landrover defender shocks from the brand you can, i am sure you will like it;).
Mixed with 2 truetracks, the combination of longer wheel travel and torsen is just great:steer:
That's a lot of info and research thanks. I only had the ironman setup for about 6 mo so I will wait another 6 mo or so then start trying to see what I can source.
My lokkas from 4wd systems came in today I was at the post office when it arrived. The box sat in customs for 43 days!
I'm planing to do the install next week.
I was out setting up our portable sawmill back in one of the remote villages, the road was to bad for the flat bed. I took two trips with my LJ78, it was exciting.
I'm hoping with the loka I will be able to go a little steadier and slower.
Chad Wells
Ok here is the lokkas the open box is the lokka for the back and the other box is for the front. I'm just going to install the back for now, as per crusher.
Geirix is helping me today he fits under the cruiser very nicely. My 6'4'' frame doesn't fit well under any rig. So I'm happy for the help
We get the third member out on the work bench and go from there.
Chad Wells
We got the third member out without to much drama. I should have removed the brake lines. I think it would have been easier and.......
The carrier came out with out a hitch, I just followed the instructions, marked both sides and kept each side separate.
Here is the carrier put back together, with the extra parts at the top of the picture. All the tolerances were spot on and it all went together just right.
All till this brake line started leaking!!
The supplied instructions were good, you just need the truck shop book as well to eliminate any guessing or broken brake lines.
We will give the lokka a good test soon, very soon
Chad Wells
