which buttons are supposed to be illuminated? (1 Viewer)
North Cadillac
I'm trying to figure out if i have burnt bulbs or the buttons just don't have lights behind them. When i installed the CDL button, it illuminates when the head lights are on, but nothing else except my stereo does. What about the antenna up-down button, hazard lights button, rear heater button and the others, do they light up in your truck?
They should all light up. You can change the bulbs in them through the white plug with the phillips screw head thing on it.
Just bought some. They run between $5 and $7 smart shoppin. Pull the switch and on the bottom side you'll see a plastic circle with a philips head imprinted in it. That's the bulb. Screw it out and put another in. Be specific about which switches are out, cause the bulbs are not the same between each of the switches.
Thanks guys. I know exactly where the little grey circle on the bottom of the switch is that you all speak of.
Just make sure you can always see/feel the go pedal :flipoff2:
cousinlover said:
Yup, they should all light up, IIRC the bulbs are about 1.50-3.00 a piece depending on the bulb for smart shoppers
Sounds like stickyfingered Arya strikes again :flipoff2:
