Where to get parts at a good price?
I need for my FJ60 the following and look for quality parts put not at a premium price:
-Clutch kit
-Transfer case rear output seal
-Manifold gasket set
-Rear differential housing gaskets
-Rear wheel bearings & seals?
Any recommendations are appreciated
Rob
For everything except maybe the rear wheel bearings, I'd go with toyota OEM parts. Check with cruiserdan at american toyota on this list. He'll give you good prices. There was a thread about front wheel bearings that was recommending the timkin from Autozone. They might also have high quality rear wheel bearings.
I second the vote for OEM and using CruiserDan. Check the vendors section for American Toyota, thats where CruiserDan works. He will stomp the price quote given to you by your local dealership.
I havent had to purchase any bearings yet, but Timken is a big brand that has been around forever. I have used their bearings in other vehicles and have had no problems.
Hodag
clutch kits can be had from Cruiseroutfitters et al, normal dealers can get pricey (dan or other discount is only way)
carolina clutch also has had cheap aisin units in the past
skip the LUK, oem style is just as good.
dealer or Cruiseroutfitters
the dual gaskets and heat deflecter are dealer
dealer, or really anyone. use the paper, cork is for inspection cover
if you can id the bearings, they can be found at bearing supply cheaper. Seals would be dealer.
jt outfitters.com
