I purchased a replacement fuel filter from CDan. The Factory Service manual tells you how to change it, but it doesn't tell you where the heck it is.....
It is a bit hard to find...it's under the manifold on the DS of the engine. Best way to see it is through the DS wheel well. To remove/reinstall, you might find it easier to get at the two bolts from underneath - you'll need long extensions though. I had a helper hold the filter in place (reaching through the wheel well) while I wrenched from underneath. Also, a trick on reinstallation is to cut one of the holes to be a slot instead. Put the bolt in first (loose of course) then slide the filter onto the bolt. You'll see which hole to slot out when you do the job.
