- Joined
- Sep 17, 2003
- Threads
- 66
- Messages
- 4,497
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
So, I've been using a conductor/connector coating material for quite a while. Was just prepping some cables today and figured I should post up the product description and how it can be used.
Most of the time I will use heatshrink with the meltable inner liner, this works great when the shrink range allows it to conform around the connector end and the cable. But, sometimes only thin wires are needed for a job (few hundred mA for relay coil etc), and heatshrink won't work.
There are some liquid 'tape' type materials out there (marine stores), but they aren't quite as good as what I've been using.
Picture of the product below and an example of its use to seal crimped connector ends. I also like to dab some on the exposed wires on ring terminals and other open/exposed crimps. Prevents and corrosion over time.
It cures pretty quickly, just a few minutes for a coating and not many more minutes when used to 'plug' up a connector opening. It remains relatively flexible so will allow a wire to move around but still provide a good seal.
Around $15 for the bottle (cap has an applicator 'brush' inside). Attempt to not inhale the fumes - quite volatile and will likely kill small endangered species so get it before CA bans it
cheers,
george.
cheers,
george.
