Wheels, tires, for 2016 4runner limited
Orem Utah
I am looking for tires and wheels for a 5th gen, 2016 4runner limited that would be good for some off roading and don’t require a lift kit. Specific specs for wheels and tires would help and pictures as well, thanks!
You're in Utah (so winter rated tire) and you want to do "some" off roading (so you don't "need" an E-rated tire).
FN Wheels - Six Shooter or FX model 17" x 8" wheels or 17" x 7.5" Toyota TRD wheels (both good and fairly inexpensive)
265/70R17 Falken Wildpeak AT3W P-metric tires (you can go as wide as 275 without rubbing)
Google for "wheel size calculator" and "wheel offset calculator" to check out different combinations.
If you go to some of the build threads they will usually tell you what they mounted in the process of their build.
Here is the link to build threads: 150-Series Toyotas
Here is a link to my thread on what I used:
