Wheel well inner fender clip part numbers?
Reading nr London, UK
Website
capeq.com
Not sure how to even describe what i'm looking for here- i hope this makes sense.
Within each wheel well, at the front of the car, are plastic liners that protect the engine from being splashed by mud and water- they are held in by lots of little round circular black clips- you push the centre in and it releases the clip. I need to replace lots of mine after braking some whilst changing the upper suspension arms.
Does anyone know the part number, or proper name for them as i can't find replacements- i suspect I'm just not using the right words when searching for the parts!
Thank you :)
Post a picture of what you need... or check partsouq for a part number...
plug in your vin number and off you go! The diagram below is for 06/07. Probably the same clips for all the years, but plug in your vin to be certain.
I'm seeing part number 90467-10186 in the partsouq image above (connect the rubber covers to the vehicle, the one surrounding the upper control arms). Generic 90467-10186 are like 10 bucks on Amazon for 30 pieces. These are pressure fit, no center push pin to lock. The generic one's look almost identical to the one's my 2001 100 series. If your talking about the hard plastic liner that fills in the wheel well, I don't believe that part/clip is on the partsourq image above.
