I am having some minor rubbing in the front and rear of my 2001 LC. I am running the Tundra aluminum wheels with 295/70R18 wheels, OME torsion bars and OME 865 rear coils. Rubbing is happening on the upper A-arm and frame. It looks like it is only happening at full lock with some suspension flexing but I am not 100% sure. I think the only time it happened was entering a drive way with some speed. I am going to Pismo this weekend for Surf and Turf so I will do some testing and determine exactly when it is happening. On the rear I see some very minor tire marks in the wheel well. Look like the same scenario here too, minor rubbing only during hard flexing of the rear suspension. The rubbing is so minor I think I can get away with a very small spacer. I found a guy local ( wheeladapter.com ) who would make me a set of (4x) 5mm or ¼ inch (my choice) wheel spacers for $180 shipped. This should push my wheel out enough to resolve the rubbing. My other choice is to purchase 1-inch wheel adapters. Here’s my dilemma, I want to keep my wheels as tucked in as far as possible. I do not want to damage my front fenders from wheel contact. This truck will see high speed wheeling where the suspension will be bottoming ( on Timbren's ) and it need steering impute. Unfortunately in these situations you have to turn while a tire is stuffed in the wheel well or you will crash. For those running 1-inch wheel spacers do you make contact with your wheel well under full compression? Has anyone damaged their fenders with 1-inch spacers? Also since I will be upgrading my suspension down the road will I need 1-inch spacers to run aftermarket upper A-arms? Thank you for your impute, I will post up some pictures of the rubbing post Pismo trip.
