Wheel Pattern on an M101 (8 Viewers)
Not either 5x4.5 or 5x5.5.
The bolt pattern is 5x112mm, converts to 5x4.41"
It is definitely an odd size
BX
Edit: The tires are about 29" in diameter I believe. Can check when I get home.
m101 fact sheet
Nolan,
Here is the poop.
Kevin
This is the route I took, as have several others on the M101 forum.
Have heard there are cheaper sources, but none found.
Dexter costs more.
BX
Switch out to a toyota axle of your liking and have handy spare parts like inner and outers, etc... built into your trailer.
kls
Dexter costs more.
BX
This is the route I took too
Heres a couple of pixs
One with just a spring over next to a stock trailer and the other is sprungover with a set of 315s on it
Glad you asked the question Nolen. It was on my list of stuff to do once I get this thing home.
did you go with the hubs with drums so the brake still works or bare hub??
either way I am interested. I can always go back with brakes later.
Hit me on my home email.
BTW, what light kit did you go with. I saw your comments on the mountings lineing up so no sense reinventing the problem.
Thanks, Ill check out wally worlds light sets.
Let me know when you sort out the spacer issue and we can sort out shipping or whatever and Ill paypal you.
Did you end up going with the wheel adapters? I'd like to do exactly the same for my Tundra (5x112 to 5x150) and could use a recommendation. No one lists this combo in their offerings...
Panzer, I bought the stuff for the 6 on 5.5 transfer and now I am leaning toward having some 5 x 112 to 5 on 150 adapters made so I can run my 100 wheels. If so, you can have my 6 on 5.5 stuff for cheap.
