ARCHIVE Whats the difference behind a 24v 5 wire External mounted Voltage Regulator and 6 Wire External Mounted Voltage Regulator ? NipponDenso OEM
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
hi i have a few NipponDenso 5 wire NOS voltage regulators
i also have 2 different 6 wire ones
ALL 24v........fyi
however i was asked for a 6 wire for a HJ61 and i can't find ANY info anywhere online except 2 different 6 wire part numbers OEM that claim to NOT interchange ?
27700-57080
27700-57090
this is very odd to have such a vacuum of no TECH after digging here on MUD in advance search too
thanks for any and all input ...........
matt
This is my 5 wire I have going on
It should cover a Bj40 , 41 , 43 , 46
But NoT a 42 ?
Maybe I’m wrong too ?
gotta be a difference between B and H series
what colour is the extra wire
and are the other five the same between the 5 and the 6 prong
just checked - 1980 Canadian bj40 24v - six wires/green connector
not a B to H change.
5 pin were maybe pre 74 or odd market/no heater
a ROUND type green connector 6pin correct ?
like this ?
NOTE: this is a sample connector ONLY photo and NOT from a related TECH> regulator topic , as it only has 5 pins too ....
Matt,
My 03/81 General Market (S. Amer) BJ40 - B engine (but, with many 3B attributes... oil cooler, late water pump, etc.) - shows a six pin regulator.
P/N: 27700-15011 is stock according to toyodiy.
Also, this is a snip from the wiring diagram that I used to rebuild the wiring harness; shows six wires to/from V/R:
enhance
I can't tell from the pictures that you posted if your 5-wire has a Yellow wire. But by the wiring diagram the Yellow wire on the six-pin V/R is optional. FWIW, that yellow wire comes FROM the (+) side of the Sedimenter warning light (before the float/switch in the sedimenter that would trigger the warning light), through a diode and into the V/R. I'll stop short of speculating on what that yellow wire DOES within the V/R 'cause I don't completely understand the relays/switches inside there...
I'm not sure this answers your original question (which, I think, was 'what do these 5-wire regulators go to.?') but I hope to help,
Trav.-
I have the 6 wire, at least count six wires, it is explained somewhere, ignition or battery: no need to try to charge if engine is off.
From here, where mine tried to fry itself, picture to large to attach so a link
UPDATE :
I have sourced a CASE of MADE IN JAPAN 6-wire 24v external voltage regulators , they will be here by weeks end
part# interchangeable
27700-57010
27700-57020
27700-57021
27700-57040
application info so far :
Matt,
enhance
Trav.-
a 27700-15011 is a 12v regulator correct ?
i have new part # 27700-15040 , it supersedes back wards and side ways a bit before i nailed this one down !
THANKS for the tech ! :)
i only pulled the case lot trigger today on 6 wire 24v made in japan regulators, because of your post , i think these are gonna help alot of folks out ,
we will see
time will tell
NOTE:
i ONLY will post Confirmed part# interchanges i confirm WITH DENSO / NipponDenso Headquarters japan ............fyi
Yeah, 12V. (again, sorry if I clogged up the thread with my non-answers.... haha)
You have a LOT of stuff I need (V/R is just one of them); I'll give ya' a call in two weeks - got some travel that I need to complete before the next parts order - but certainly I am at the point to need a bunch of vintage, quality, TEQ, correct stuff!!
Your Input Master Chief IS ALWAYS welcome and VALUED in my threads ............ :beer: :)
I think maybe it's time to call in MY personal Expert on regulators ........
@bj40green Rudy wrote a College professor LEVEL Thesis on regulators , just not sure how much was 24v related ?
time refresh Mr. Rudy's passionate thread of a helpful nature ..
I will post the link once i find it again ...HERE
ALL 24v........fyi
27700-57080
27700-57090
matt
The voltage regulator of my 24v HJ61 just died.
I am searching for a replacement. Part reference 27700-57090 (what I had) isn't produced anymore but I can still source 27700-57080. From what I understand 27700-57090 is 24v 30A, and 27700-57080 is 24v 25A.
Can anyone confirm, and most importantly are these parts interchangeable?
Cheers
Cheers
hi ,
i offer this ....
it covers your 27700-57090
- this is a MADE IN JAPAN NEW part
let me know if i can furter help
thanks
matt
hi ,
i offer this ....
thanks
matt
Thank you. What is the amperage of your regulators?
