What's in your 100-series tool kit?
Just get a variety pak for the fuse; always need a few trying to figure out what's happening. I went thru 6 15'swhile trying to figure out my seat warmer problem :(
Large inverter, and prophylactics.
What's that I can't hear you over the sound of my seat heaters. Seriously, that might be the biggest reason I have a 100 vs an 80. That and cup holders. Feel free to judge :).
Does anyone have a link or specific advice to a nice spare fuse "kit" Fuses are always needed and often mentioned but has anyone picked up a nice, mostly "all inclusive" package of various fuses? If so from where? Which type in particular? I see several types on Amazon or Autozone but am not sure what's best.
This was the only "kit" I found: Fuse/Accessory Kit-small
It's listed under LC100 but the description mentioned LC80, so I'm not sure if it fits LC100.
Let's ask @NLXTACY; any chance you have one for a 100 series in the works?
The description is my fault. It'll fit 80s as well as 100s. I had some 80s guys complain that there were fuses they didn't need. Yeah, cuz those work for the hundy folks ;)
Ditto here @NLXTACY - I'm going to have to order one of these.
I looked at the fusebox under the engine hood of my '05 LC. All fuses there appeared to be MINI fuses, but according to the description the kit contains mainly ATO fuses. I believe ATOs are bigger than MINIs and will not fit. I haven't looked at the fuses under the side kick panels though. Also, there's a 25A in the fusebox but I didn't see a 25A in the kit description. Maybe the description isn't accurate?
Well crap. To be honest I didn't check the later model 100s. This is very interesting. I need to reevaluate the marketing on these. There is a split between the 60 and 62 going from glass to plastic fuses.
Tool drawer:
Quart of oil
12oz windex
4 pairs of nitrile gloves
2 pair of safety glasses
Craftsman 18in flex head ratchet
Small craftsman strap wrench
Sharpie silver
1 roll of 3m duct tape
22mm deep impact half inch socket
2oz jb weld
Kd tools 2289 Pittman arm puller
Permatex black silicon 3 ounce
Permarex ultra grey silicon 3.5 ounce
Sta-lube synth grease 2.5 oz
36 inch tape measurer
Jack demolition bfh 16 inch hammer 4lb
16 inch craftsman rubber mallet
1 can of pb blaster
1 pair heavy leather gloves
3 emergency flares
1 pair lg mechanics gloves
1 pair medium mechanics gloves
Arb speedy seal puncture repair kit
Craftsman mini razor knife
Craftsman 44202 - 18 in breaker - 1/2 in drive
Zip ties 14in GB 75 lb cable tip qt 100
24 inch cable tie qt 10
Urgo dine #5870 tool roll up
Milwaukee LED work light rechargeable + Milwaukee m18 red lithium Xc battery
Craftsman tools:
24in 15lb magnet
Professional #2 Philips
Professional 1/4 standard
43373 bit driver + Dozen associated bits
Plastic spudger
46679 - 11 piece hex metric
8in crescent wrench
45075 cutter
45378 plier
45103 needle nose
Wrenches, One each 12 point/6point:
8mm
9mm
10mm
11mm
12mm
13mm
14mm
15mm
Singularly 16,17 - 12 point
18mm - 6 point
Pair of channel locks. 440s - 10 inch
Snap on #2 Philips stubby
Craftsman large folding razor knife
Recovery gear:
2x arb 3/4 in shackles
Smiddy built hitch recovery eye
2x 30 foot 18,000 lb recovery strap
Craftsman 13in tool bag
Milwaukee 2625 - 20 hackzall
Milwaukee 2662-20 1/2in impact
Milwaukee 48591812 battery charger
1/2dozen assorted hackzall blades
Milwaukee tool bag 12 inch
Pelican 1060:
Sockets 6 point 3/8 :
8, 10, 11, 12, 13, 14, 15, 16, 17, 18
Sockets 6 point 1/2 in:
19, 18, 17, 16, 15, 14
2x 12 point 3/8inch 14,17
30mm 12 point 1/2in drive
3/8 inch deep: 18, 15, 14, 13, 12, 10
5/8 spark plug socket 3/8in drive
43398 3/8in thumb ratchet
3/8in : 3/8in swivel head
1/2in : 3/8in adapter
6in 1/2in drive extension
Craftsman 13 inch tool bag:
3/8in ratchet 44808
1/2in ratchet 44809
44500 bottle opener
3in & 6in extension 3/8 drive
Milwaukee mini hack saw w/10 in blade
Bondhus 9 piece Allen wrench set metric
Bondhus 9 piece Allen wrench set SAE
Craftsman 46286 torx key set
6in x 1.25in brass drift
Safety wire pliers
100feet of safety wire
Where do the passengers sit?
