- Joined
- Sep 4, 2020
- Threads
- 119
- Messages
- 1,584
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
Wasn't sure where to post this question.
The specific parts are a tapered threaded port on the water pump (and engine block) of B Series diesel engines, but the question is a general one. It relates to parts from Toyota with the 6th and 7th numbers '52'. So, for example:
90345-52001 - this is a tapered blanking plug which is used on the water pump (no ACSD) and as an oil gallery plug on the block of a 3Bii or 14B.
90404-52028 - this is a water outlet union which connects the water pump to the ACSD on a 14B.
The plug mentioned above is used on dozens of different Toyota models.
I have a 'G1/4-19' parallel (bottom) tap, which I believe is a BSP thread. It's 19 TPI (not the 18 TPI of the American NPT system). But I cannot get the tap into the tapped hole on a 14B water pump. The shank of the tap will fit snugly down the tapped hole, but I cannot get the tap threads in.
Could anyone suggest what's going on here? Is the hole perhaps indeed 1/4"-19 TPI but made with a tapered tap?
Or is there another tapered tap system which is very similar.
The reason I want to know is that I wish to tap out a temperature sensor hole on my water outlet to accept the above mentioned water outlet union to connect a turbo coolant bypass hose.
Thanks!
Thanks!
