What octane do you run?
Regular or Super?
  • Total voters
    187
I ran premium in my 06LX for a few years with the same thinking (I can’t get e free anywhere near where I live), figuring it was probably better fuel.
Following a tip from the boiling fuel thread though, I’ve switched to regular with no noticeable difference in performance the past 10k mikes or so. The idea is that ethanol is added as a cheap way to boost octane. So, lower octane fuel is likely to have less ethanol actually added. Cheaper and less corn. Win win.
Or maybe it’s bs
Ethanol was never introduced into automotive fuel to boost the octane rating. It was introduced by the Carter administration as a knee jerk response to a perceived lack of crude oil, back when were were
a) supposed to run out of petroleum reserves by 1995 and
b) supposed to overpopulate the world by 2000, and run out of food, and
c) die because global cooling had shut down the world's thermostat.
It was also a sop to the Democrat run congress who helped elect Carter, so that the corporate farms (like ConAgra) could clean up. We're still paying for that foolishness.
Keep in mind the octane rating at the pump is the minimum. If you’re selecting 87 you could very well be getting 92. So what you’re paying for may not be the reality of what you’re running.
10-4,
I have access to non-ethanol 87 (Hot Spot has it...) so I may try it....
I usually get gas at one of the 'QP" stations as they have the 93 Ethanol Free, yes it costs more but the 100 isn't my daily driver...
It does return the best fuel economy so far, lol...
I'm curious if this also applies to the Lexus GX460 that use the 1UR-FE?
We ran 87 in the 01 LC almost exclusively except some of the times we were very heavily loaded and in hilly terrain. Then we would run 89 or 91+. I noticed no change in mileage between tanks. Mileage consistently improved in higher altitudes (>4000 ft) regardless of the fuel grade.
When we got the 01 LX, the dealership told my wife it should use premium, even though it was no longer "required" in 01. So it got premium. I did some comparison with 87. Initially I could not tell any significant difference. But cruise control on rolling terrain was the first note of a difference. Driving the same hwy on 87 required more frequent downshifts by the cruise control on the incline portions; whereas 93 had notably fewer downshifts. This led to noticing other subtle differences in acceleration pedal responsiveness and shifting. Gas mileage difference was essentially negligible, with the LX getting slightly better than we did with the LC (LX= 14.3, LC = 14.0 overall).
Reading Toyota literature, all Toyota engines are made to adjust to the fuel in them and the engine controls will adapt. The adjustment is quick to a lower octane, but slow in recovering to tanks of higher octane fuel. Typically, it will take multiple fills of 93 to return to full efficiency. Comparing the same engine specs with Lexus showing 91 octane and Toyota showing 87 octane shows HP to be adversely impacted by <10 HP.
The cruise control comparison on the same stretches of hwy became a good test for other Toyota vehicles; and the frequency of downshifts on inclines was a factor, regardless of whether the vehicle was rated for regular or premium. Driveability and responsiveness in heavy traffic is also a notable distinguishing observation; again regardless of the fuel designation. Lexus is designed for smooth pedal response and minimal downshifts on the highways - for this 91 octane fills the bill. It will run on 87, but the pedal responsiveness will be a bit more jerky and downshifts on the highway more frequent. Neither octane resulted in engine knocking in any of our Toyota/Lexus vehicles; it is really about engine control and drive train timing. I usually would use 3 tanks of 93 before making the comparisons. So when heavily loaded, or in demanding situations, 91+ has a notable benefit. If you want a smoother, more responsive engine, then 91+ will have a benefit for essentially any Toyota engine in the past 20 years. If you want specifics, you can check the Toyota Training Course materials on the TIS site that cover engine controls. The takeaway for me was that Toyota designed their engines to run on a wide range of fuel octanes, so even those designed for 87 will respond with enhanced performance charateristics when using 93. So it is not as simple as Consumer Reports may lead one to think, the modern engine controls optimize performance of an engine based on the fuel it is using - thus affecting horsepower, torque, efficiency, and mileage.
Now that I am used to how our Lexus and Toyota vehicles drive with 93, the difference is noticeable when we use 87; even in vehicles designating 87. We only use "Top Tier" rated fuel.
